Architecture of Dynatrace deployed as SaaS
What does the Dynatrace SaaS architecture look like? Where are the responsibilities (RACI Matrix), regulations, etc.?
Dynatrace is the only solution on the market architected with dynamic, web-scale cloud-native technologies. Running on public clouds, Dynatrace is built on an elastic grid architecture that scales to 100,000+ hosts easily. We use the most robust enterprise-proven cloud technologies to provide a monitoring solution as resilient and available as the systems it monitors.
  • Cloud-native computing
  • Cloud-native block and object storage
  • Automated Load Balancing
  • Grail
Moreover, Grail supports massive volumes and types of logs and events without indexing, re-indexing, and schema management requirements. Grail handles ever-growing data volumes and provides up to a 100X speed advantage over existing solutions thanks to its data lakehouse architecture with a massively parallel processing (MPP) engine.
more at: What is Dynatrace Grail? — Dynatrace Docs
If you want to get into details regarding the architecture, responsibilities, and regulations - let’s get in touch! Start by asking your Dynatrace ONE assistant on the in-product assistance chat
