I have a simple question about the logging on OneAgent injection.
I’m sure that oneagent logs will be updated when we install oneagent into hosts.
Then, are also application log files updated after oneagent is installed and injected into application?
Kohei
Hi Kohei,
Yes, you can see oneagent related entries in your application log files. I have seen in my application log files. Like the oneagent path, oneagent lib path and something like if the application fails to open the oneagent log file then can see those errors as well in your application logs. Hope this helps.
Regards
Muthu
