Hello!
Although it seems counter-intuitive I was wondering if there is any possibility to assign a OpenShift pod to a hostgroup?
When deploying the oneagent to OpenShift I can use an InitContainer. This works fine and one can easily add custom metadata properties to the process that runs within the container.
But i was wondering - sine the pod is represented as a host in Dynatrace - how one could assign a hostgroup to this “Host”. This would be really helpful e.g. in the case of using Management Zone filters the same way how one would use them for normal hosts.
It’s a PaaS agent that is injected into the application only, but since the “host” is created as entity I was thinking maybe environment variables could be used to force the host group?
Any ideas?
