The workflow is functioning as expected, and the emails are being received. However, the data in the email is not formatted properly. Below is a snapshot of the data that is being received:
I would recommend using a similar format as how custom events for alerting works where you leverage Placeholders to provide dynamic variable data like " Host {Host.Name} reported high CPU with a value above {Baseline}. "
Granted that is not the value you will use, but it showcases the mind set of using dynamic variables you set within your grail query. Much like you did for {Record}. You can also use the right hand tab to test the result to verify the data is properly formatted without spamming emails.
Hi there. One limitation you will need to keep in mind is that sending email with Workflows currently only supports plain text, as mentioned in the documentation. You will need to format the body of your email accordingly so that it generates a legible message body within the constraints of plain text. That formatting would likely live inside the loop (between lines #1 and #3) and involve a mix of actual text and specific values from your results.
