I am doing the “taste the test” and one of the questions does not provide enough context, and isn’t a multiple answer question. From my understanding it is either of the 1st 2 options…
I am a Managed DT user, so I don’t know the SaaS side of it, but from the documentation it appears to be fixed, while managed is configurable to 35 days. Am I missing something? Or is the question missing context?
Data retention periods are visible in the following page:
In Managed you have a certain control in those periods. In SaaS, they are mostly fixed.
I agree that the question is not well addressed. If I had to reply, I would choose the one that applies to SaaS, #1.
Olá @GilesDay
Isso é corrigido em 35 dias, verifique:
com dynatrace gerenciado você configura em até 35 dias
Dynatrace fixed the question by adding in the context (SaaS or Managed), as it could have reasonably been either 35days or configurable up to 35 days, depending on how you read the question.
Here is the question now
Should this be fixed because it mentions SASS?
