I trying to apply tags on OS Services like:
for os services running on host abc the tag should be “host: abc” which is usually achievable for processes and services but for entity selector based rules the place holder is not available.
Is there any other way, by which I can achieve this?
You can create a rule using entity selector:
type(os:service),fromRelationship.runs_on(type(host),tag(XXXX))
Best regards
I have already tried this, the problem here is only one value will be applied to all the OS Services running on the hosts having that tag but I want the value to be dynamic based on host name and place holders are not applicable for entity selector based rules 😐
I would say using API / Monaco / Workflows for automation. When a host is onboarded, a script will create that tagging rule.
Best regards
