Autoinjection script with custom context path
By default dynatrace scripts are injected into head section with root context path like
<script type=“text/javascript” src=“/ruxitagentjs_ICANVfqru_1029924090310435ssd4.js”…>
I was looking in Dynatrace settings where I can define context path so that scripts injected will be with custom context path (/webapp/bio/).
<script type=“text/javascript” src=“/webapp/bio/ruxitagentjs_ICANVfqru_10299240903104354.js”…>
Hi @viveksingh87 ,
You can change it  going to Settings of your application,  Capturing > Advanced setup, RUM monitoring code section and specify path for RUM monitoring code:
Hope it helps.
Elena.
Be aware that the path Elena mention does not need to exist, the oneagent will take care of the new path.
Thank you Elena,
I have also tried configuring “/webapp/bio/” under Capturing > Advanced setup and checked application head tag in browser still script does not have context path. Does one agent look for context path from any tag on index.html
Hi @viveksingh87 ,
When you say “Does one agent look for context path from any tag on index.html”, do you mean to place ruxit on index.html? If you mean this, you can define a custom injection rule to inject ruxitagent on index.html:
Elena.
I have setup that as below
but even after that script does not prefix context path “/webapp/biometric/”
As a result script failed to download
Hi @viveksingh87 ,
That you’re trying to get is inject ruxit on page “/webapp/bio/” and change the ruxitagent path from “/ruxitagentjs_…js” to “/webapp/bio/ruxitagentjs_…js”, right?
Have you tried to specify the path from RUM monitoring code in Advance Settings and also defining the custom injection rule?
Elena.
Yes I have tried that. I have updated the path from RUM monitoring code in Advance Settings and also defined the custom injection rule.
Hi @viveksingh87 ,
If you go to Application > your_app > Settings > Injection, Manual insertion, do you see the desired path?
Something like
<script type=“text/javascript” src="/webapp/bio/ruxitagentjs_ICANVfghqru_10299240903104354.js" data-dtconfig="app=---…</script>
Maybe you have to copy the snippet in your page. As far as I know it shouldn´t required but you can test it.
Or someone can provide a better answer than mine.
Elena.
