Hi , I am trying to create a workflow in my Saas tenant but getting this error "Uncaught (in promise) 400: TOO_FEW_PARAMETERS_FOR_FUNCTION. exceptionType: “DQL-SYNTAX-ERROR”. syntaxErrorPosition: {“start”:{“column”:82,“index”:81,“line”:1},“end”:{“column”:93,“index”:92,“line”:1}}. errorType: “TOO_FEW_PARAMETERS_FOR_FUNCTION”. errorMessage: “There aren’t enough parameters for function in(). 1 mandatory parameter is missing: haystack. haystack: The elements where to search for the needle element (t”
I thought may be dynatrace-sdk/automation-utils needs to be installed first , but npm install @dynatrace-sdk/automation-utils is also failing. Does anyone know how to solve this issue?
Thanks!
