We are proposing Dynatrace(SaaS) to a customer who is considering to deploy 200-1000 agents to their datacenter.
And the data center already has “AWS Direct Connect” to AWS as the dedicated line.
In this case, do you have a recommendation to use AWS Direct Connect between the local data center and the AWS(Dynatrace SaaS)?
And is it possible to use AWS Direct Connect between DC and Dynatrace SaaS in the first place?
Best Regards,
Noah Kobayashi
