@karolinaboba
Our recently installed ActiveGate always tries to connect to another region than eu-central-1. Can you explain how to configure the ActiveGate exactly to use only eu-central-1 as region?
If you want per-credentials configuration, you can add the undocumented suffix to credentials label:
My Prod AWS Credentials @REGIONS={us-east-1|us-east-2}
Please mind from Dynatrace version 1.329 AWS STS global endpoint is not supported and now it uses regional endpoint. `us-west-2` region became the default region for `ActiveGate` so you need to ensure that `sts.us-west-2.amazonaws.com` endpoint is enabled to maintain connectivity.
