Hi community,
I’ve got a question about both the Azure and AWS cloud integration. For both, there is a possibility to add extra services.
Dynatrace will then start pulling extra information out of the Cloud APIs.
Whilst investigating the possibilities I see that there is a lot of documentation about the services and which metrics they pull, that’s good. But some services contain pre-defined custom metric events that can be used for alerting:
Unfortunately, I can’t find documentation about the available alerts. This would mean that I need to activate everything just to see if custom events apply for a service.
Does anybody know if I can find a list of available metric event for AWS and Azure somewhere?
KR.
Michiel
