AWS RDS Proxy Monitoring
I want to monitoring AWS RDS-proxy metrics in Dynatrace.
The metrics provided by cloudwatch are as follows.
Can Dynatrace monitor these metrics?
Hi there,
What I would recommend is to double-check all the supported metrics which is monitored by default:
- Default AWS metrics
AWS RDS-Proxy metrics are not captured by default, but by looking into the screenshot I would suggest the supporting services which would help you gain more insights from the AWS cloudwatch:
- AWS supporting services
The links above do not reference AWS RDS Proxy.
Will the new STREAM method perhaps be an option if we ingest AWs Cloudwatch metrics?
