AWS SQS Monitoring
HI
Is there any way to monitor AWS SQS queue size and also dlq with Dynatrace SaaS?
br
Farid
Is there any support for this yet?
No change to the answer above - work is progressing and we are aiming Sep/Oct timeframe for the release.
Hi. Do we have some exact date now? Dynatrace is behind in some other tools to support AWS native services monitoring.
Development is almost finished. We should start EAP with S157.
As Pawel mentioned, the EAP started with S157.
All details and registration link can be found in this blog post.
EDIT:
Note: as of 11th of March 2019 the registration for EAP has been closed.
The blog link is broken.
Thanks for noticing that. Link to blog fixed and note about EAP being closed added.
