Azure Automation Account - Missing metrics Hybrid worker Ping
We have 4 metrics in our Azure Automation Account(attached screenshot), but Dynatrace’s Azure Monitor metrics integration only pulls 3 of them and skips the Hybrid Worker ping metric Azure Automation Account monitoring - Dynatrace Docs. How can we get the missing metric? Is it possible to pull it in?
TIA
Hi @Devipriya ,  I think there are the only three metrics available at this time from dynatrace via the exiting integration
You might want to raise it as an idea to have the Hybrid worker Ping added or create a custom metric/extension to query the metric you need using API  as an example
How often Dynatrace update the version of the Azure Monitor Metrics API, and how can we adopt the new version?
Hybrid worker ping is now available in Dynatrace
