Azure Connection - communication error
while trying to create a azure connection, we have a “communication error” ,
this error should be more detailed.
the connection in a similar system is allready working. so credentials, tenandid etc. are correct.
where can I find the detailed error log?
regards
André
It’s SaaS or managed? If Managed, you can open Server.0.0.log and find details of error that connection issue. If there is SaaS, open support ticket, they have access to this log on their side. They can check it for you.
was this resolved as I have the same issue?
Can you upload an image of the error?
regard!
Hi,please let me know whether your issue resolved or not .I am also facing the same issue
Hello everyone,
You can check out a similar thread in the Community, where @rodrigo_alvare1 provided a solution with a list of steps to check when connecting Azure to ActiveGate. Hope that helps!
Connecting Dynatrace to Azure monitor - Communication error
