Azure Monitor API call frequency
When integrating Dynatrace with Azure to collect data from Azure Monitor, docs say Dynatrace queries Azure Monitor API every 5 minutes.
Is it possible to decrease the period to one minute in order to achieve faster feedback?
Aren’t 5 minutes too long period to detect any important system events?
Hey Mkulov,
You can view all possible activegate configurations including the Azure ones as specified here: Configuration properties and parameters of ActiveGate — Dynatrace Docs
As far as I can tell there is no such configuration to change the polling rate. The list of possible configurations in config.txt which is mentioned in the above docs is as follows:
Hope this helps!
