Can we monitor any PaaS service on Azure cloud using azure site extension. or Do we have a list of PaaS services which we can monitor through Dynatrace. I am having applications like Azure HD Insight, Azure Data Lake..
Hi Suresh,
Yes, Azure App Services are supported and the oneagent can be enabled via our site-extension. For more info please have a look on this page: https://help.dynatrace.com/infrastructure-monitoriā¦
List of supported services is coming soon.
Generally speaking of fully managed Azure services, we will support them in upcoming Azure Monitor dashboard. In the meanwhile, you can push all required monitoring metrics directly into Dynatrace via our API or a custom-plugin.
Patrick
@ Patric T.
Is there any update on this ,when this feature is going to be available .Do we have support for Apache Kafka, Spark, Hive, Hbase, Data Lake in the upcoming feature.
Hi Patrick,
Is there any support for Data Lake till now.
you can see the support for the azure components through the site below.
