Hi community,
What is the indication of high background thread CPU (more than 10%) on IIS App Pool .NET v4.5 2 process? What can we suspect from there?
Thanks.
Hi community,
Thanks.
Hi @leonatay
The background thread CPU refers to everything that happens outside the monitored request. We can try to create custom services to capture the information that is done there.
Radek
Hello @leonatay,
Perfmon and DebugDiag, you can collect data that can be helpful in determining the cause of high CPU in application pools.
Once you have confirmed that a w3wp.exe process is experiencing high CPU, you will need to collect the following information in order to determine what is causing the problem:
Cheers!
RN
