Before enable deep monitoring for a pod or namespace the memory resource check is required
Hi Folks,
Based on the documnetation there is a memory overhead of the dynatrace code module (100 - 200 MB).
OneAgent memory requirements — Dynatrace Docs
Nowdays I met some kubernetes / openshift clusters with very limited memeory resources. I have created a high level qucik dashboard, to check the memory limit and memory usage metrics. Free memory limit / pod  should be higher than the overhead.
Maybe it is useful for you also.
Best regards,
János
