We are designing bidirectional synthetic monitoring where:
- AWS environment monitors 2 endpoints hosted in OnPrem
- OnPrem environment monitors 2 endpoints hosted in AWS
We are evaluating the best monitoring approach:
- DNS Network Monitor
- TCP Network Monitor
- HTTP GET
- HTTP POST (transaction validation)
One view is that DNS validation is sufficient since every HTTP/TCP request requires DNS resolution and some cloud-native workloads (e.g., Kubernetes/EKS) may have dynamic backend IPs. Another view is that DNS-only monitoring doesn’t truly validate traffic flow, application reachability, or service availability. “We are goona use Private AG for the configuration - suggest best prectice(the requirements is like - to validate the flow from each DC to another DC hosted urls,api - major thing is to validate the flow is up and running) and also suggest if we configure the url-api for synthetic endpoint with get call then which code can be used so it can denote the network flow or traffic is not right like 504 only? do suggest.”
Questions
- From a Dynatrace architecture perspective, what is the recommended approach for validating cross-environment flow and availability?
- DNS
- TCP
- HTTP GET
- HTTP POST
- Combination of approaches
- Is DNS-only monitoring considered sufficient for availability validation, or should it only be a supporting signal?
- For cloud-native applications where backend IPs change frequently, is hostname-based monitoring via HTTP/TCP the preferred approach?
- We want to create a single problem card only when:
- Multiple synthetic endpoints fail (4 endpoints across 2 environments)
- A related service simultaneously shows elevated failure/error rates
What is the recommended correlation approach in Dynatrace?
- Davis AI
- Metric Events / Anomaly Detection
- DQL Events
- Workflows
- Combination of the above
Looking for best practices and real-world implementations.
