Biztalk monitoring Dynatrace Managed / SaaS
Good Day
Ihave a client that needs to monitor Biztalk as they are migrating from Appmon to Dynatrace Managed / SaaS.
Is there out of the box support for Biztalk, not Host metrics but deep dive? On Appmon a plugin was available.
Has anybody done this before and what insight can be shared.
Do’s and don’ts
I’m also looking for info on Biztalk monitoring with Dynatrace. Mias, did you eventually get any help via other channels?
Not as yet
Hi Guys,
I also have a client using BizTalk.
The application is recognised as a .net application, but there is not much interesting to see. No consolidated service flow,… I think some extra development needs to be done here.
Please go and upvote the RFE and submit your comments / requirements:
Hi Guys,
Any update for this topic ?
I need to monitor some Biztalk services.
Hello all,
There is an extension for BizTalk in Dynatrace Hub, that is supported and developed by our partners. You can check it out here:
HI @MaciejNeumann
I already used this plugin, but its only showing the metrics and not the services.
Hi @Malaik, were you able to get APM information on BizTalk in any way?
Yos
no, Only metrics.
No requests inside the services.
Thanks @Malaik for your confirmation - very sad :disappointed_face:
BTW, From where can we download the extension to see those metrics?
Yos
Click on get started and a form will open to contact the partner.
