I am attempting to build a demo plugin in my Linux virtual machine and got this status code: status code: 400 {“error”:{“code”:400,“message”:“VALIDATION_ERROR_VERSION_CONFLICT”}}
Below are the commands that I have executed:
[jc@jc demo_activegate_plugin]$ sudo plugin_sdk build_plugin
[sudo] password for jc:
Arguments=Namespace(deployment_dir=None, no_cert_ver=False, no_upload=False, plugin_dir=‘/home/jc/ag_plugin/examples/demo_activegate_plugin’, server=None, token=None, token_file=None, verbose=False)
Starting oneagent_build_plugin
Checking plugin metadata: /home/jc/ag_plugin/examples/demo_activegate_plugin/plugin.json
Validating plugin.json against schema
“processTypeNames” is deprecated in custom extension JSON definition file. Please use “technologies” instead.
Plugin data: Plugin name=custom.remote.python.demo, version=1.3
Cleaning up previous build information
running bdist_wheel
running build
running build_py
creating build
creating build/lib
copying /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.py → build/lib
installing to build/bdist.linux-x86_64/wheel
running install
running install_lib
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/wheel
copying build/lib/demo_activegate_plugin.py → build/bdist.linux-x86_64/wheel
running install_egg_info
running egg_info
creating /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info
writing /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info/PKG-INFO
writing dependency_links to /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info/dependency_links.txt
writing requirements to /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info/requires.txt
writing top-level names to /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info/top_level.txt
writing manifest file ‘/home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info/SOURCES.txt’
reading manifest file ‘/home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info/SOURCES.txt’
Copying /home/jc/ag_plugin/examples/demo_activegate_plugin/demo_activegate_plugin.egg-info to build/bdist.linux-x86_64/wheel/demo_activegate_plugin-1.3-py3.8.egg-info
running install_scripts
creating build/bdist.linux-x86_64/wheel/demo_activegate_plugin-1.3.dist-info/WHEEL
creating ‘dist/demo_activegate_plugin-1.3-py3-none-any.whl’ and adding ‘build/bdist.linux-x86_64/wheel’ to it
adding ‘demo_activegate_plugin.py’
adding ‘demo_activegate_plugin-1.3.dist-info/METADATA’
adding ‘demo_activegate_plugin-1.3.dist-info/WHEEL’
adding ‘demo_activegate_plugin-1.3.dist-info/top_level.txt’
adding ‘demo_activegate_plugin-1.3.dist-info/RECORD’
removing build/bdist.linux-x86_64/wheel
Leaving directory /tmp/tmpghifcabf
Created distribution of the plugin: [(‘bdist_wheel’, ‘3.8’, ‘dist/demo_activegate_plugin-1.3-py3-none-any.whl’)]
Installing plugin to temporary location
Processing /tmp/tmpghifcabf/dist/demo_activegate_plugin-1.3-py3-none-any.whl
Collecting requests>=2.6.0
Using cached requests-2.28.1-py3-none-any.whl (62 kB)
Collecting certifi>=2017.4.17
Using cached certifi-2022.9.24-py3-none-any.whl (161 kB)
Collecting charset-normalizer<3,>=2
Using cached charset_normalizer-2.1.1-py3-none-any.whl (39 kB)
Collecting urllib3<1.27,>=1.21.1
Using cached urllib3-1.26.12-py2.py3-none-any.whl (140 kB)
Collecting idna<4,>=2.5
Using cached idna-3.4-py3-none-any.whl (61 kB)
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests, demo-activegate-plugin
Successfully installed certifi-2022.9.24 charset-normalizer-2.1.1 demo-activegate-plugin-1.3 idna-3.4 requests-2.28.1 urllib3-1.26.12
WARNING: Running pip as root will break packages and permissions. You should install packages reliably by using venv: 12. Virtual Environments and Packages — Python 3.15.2 documentation
Copying plugin to target_directory: /opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna-3.4.dist-info
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/bin
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/plugin.json
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/packages
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/_collections.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/_version.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/connection.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/connectionpool.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/exceptions.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/fields.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/filepost.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/poolmanager.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/request.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/response.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/_securetransport
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/_appengine_environ.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/appengine.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/ntlmpool.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/pyopenssl.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/securetransport.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/socks.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/_securetransport/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/_securetransport/bindings.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/contrib/_securetransport/low_level.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/packages/backports
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/packages/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/packages/six.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/packages/backports/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/packages/backports/makefile.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/connection.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/proxy.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/queue.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/request.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/response.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/retry.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/ssl_.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/ssl_match_hostname.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/ssltransport.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/timeout.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/url.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3/util/wait.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info/LICENSE.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info/METADATA
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info/WHEEL
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info/top_level.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info/RECORD
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/urllib3-1.26.12.dist-info/INSTALLER
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/codec.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/compat.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/core.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/idnadata.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/intranges.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/package_data.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/py.typed
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna/uts46data.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna-3.4.dist-info/LICENSE.md
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna-3.4.dist-info/WHEEL
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna-3.4.dist-info/METADATA
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna-3.4.dist-info/RECORD
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/idna-3.4.dist-info/INSTALLER
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/assets
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/cli
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/api.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/cd.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/constant.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/legacy.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/md.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/models.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/py.typed
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/utils.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/version.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/assets/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/cli/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer/cli/normalizer.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/LICENSE
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/METADATA
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/WHEEL
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/entry_points.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/top_level.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/RECORD
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/charset_normalizer-2.1.1.dist-info/INSTALLER
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi/__main__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi/cacert.pem
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi/core.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi/py.typed
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info/LICENSE
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info/METADATA
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info/WHEEL
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info/top_level.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info/RECORD
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/certifi-2022.9.24.dist-info/INSTALLER
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/__init__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/__version__.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/_internal_utils.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/adapters.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/api.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/auth.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/certs.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/compat.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/cookies.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/exceptions.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/help.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/hooks.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/models.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/packages.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/sessions.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/status_codes.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/structures.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests/utils.py
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info/LICENSE
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info/METADATA
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info/WHEEL
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info/top_level.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info/RECORD
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/requests-2.28.1.dist-info/INSTALLER
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/METADATA
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/WHEEL
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/top_level.txt
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/RECORD
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/INSTALLER
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/direct_url.json
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/demo_activegate_plugin-1.3.dist-info/REQUESTED
/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo/bin/normalizer
Creating plugin archive
Plugin deployed successfully into /opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo
Plugin archive available at /opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo.zip
interactive upload → oneagent_upload_plugin -p /opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.demo.zip -s https://xxxxxxxxx.live.dynatrace.com:443/api/v1/remoteplugins -t ################################################################################################
Attempting to send plugin to server https://xxxxxxx.live.dynatrace.com:443/api/v1/remoteplugins
server https://xxxxxx.live.dynatrace.com:443/api/v1/remoteplugins/ returned status code: 400 {“error”:{“code”:400,“message”:“VALIDATION_ERROR_VERSION_CONFLICT”}}
Please execute oneagent_verify_plugin before upload to validate plugin.json against the schema
[jc@jc demo_activegate_plugin]$ oneagent_verify_plugin
Arguments=Namespace(plugin_dir=‘/home/jc/ag_plugin/examples/demo_activegate_plugin’, verbose=False)
Starting oneagent_verify_plugin
Plugin custom.remote.python.demo is valid
I installed the SDK on my ActiveGate and am running this command from within my ActiveGate.
