Built-in metrics in Grail
I have try to use the new Grail visualisation with metrics
However, some builtin metrics are not existing yet in Grail (I am using this as reference Built-in Metrics on Grail — Dynatrace Docs)
I am thinking of synthetic metrics : Browser monitors metrics are not there (it’s only one example..)
Will it be available soon and migrated over the time ? any timeline ?
Best regards,
Christophe
We’re gradually working on migrating metrics to Grail and we’re at the moment working on the first Synthetic metrics. We don’t have a timeline for when all of the Synthetic metrics will be available in Grail but you’ll gradually see more and more of them available in Grail as we progress with the migration.
We have slightly changed the strategy of synthetic metrics rollout.
First set of metrics will be available as a preview with Dynatrace version 269. It will cover huge majority of HTTP and 3rd monitors metrics plus basic set of Browser monitor metrics.
I will be happy to discuss reasons details of your use case, what are the main goals you would like to achieve with synthetic metrics in Grail.
I would like all community participants to consider my comment as an invitation to such discussion and participation in preview. Please, leave comment under that message if you’re interested in.
Best Regards,
Jacek
Hi Jacek !
Unfortunately, I missed your response  in May …
but if you need any feedback about synthetic metrics, I’ll be happy to discuss.
Christophe
Synthetic metrics are showing up as “available in Grail”
But when I query in a notebook, I get no data? :disappointed_face:
Am I missing something?
You are not missing something there.
it’s just like that, gradually every metric will be on DQL for now they are just empty buckets
but if you need it now on dashboards gen 3, you can always use the sdk
import { metricsClient } from '@dynatrace-sdk/client-classic-environment-v2';
export default async function () {
    const metricSelectorString = "builtin:service.response.time:splitBy():fold:avg";
    const resp = await metricsClient.query({
        metricSelector: metricSelectorString,
        acceptType: "application/json; charset=utf-8",
    let outarray = [];
    for (let rate of resp.result[0].data) {
        let i = 0;
        for (let ts of rate.timestamps) {
            i++;
            let date = new Date(ts);
            outarray.push({
                'Timestamp': date,
                'miliSeconds': rate.values/1000,
    return outarray;
Synthetic metrics like those ones are not (yet) in Grail. Currently it’s in closed preview but not publicly available
And @rgarzon1 explained how to get “classic” metrics in new UI dashboards.
Best regards,
Christophe
I would like to have a shorter retention for the metrics from my non-prod resources, any info on when we will be able to create a storage bucket for metrics and direct metrics to that custom bucket with less retention?
Hi @rgarzon1 ,
Thanks for sharing the above code, can you help us on this we have the query in data explore : “builtin:service.dbconnections.failure:filter(and(or(in(“dt.entity.service”,entitySelector(“type(service),tag(~“atlas_db~”)”))),or(in(“dt.entity.service”,entitySelector(“type(service),tag(~“environment:prod~”)”))))):splitBy(“dt.entity.service”):sort(value(auto,descending))”
When I am passing this on metricSelectorString it is giving error. Can you help us on adjusting the above code where I want to see failed bd connects with some tags as filter to minimize the records.
Parkash
Probably its because you are trying to put double quotes ? you can use this
const metricSelectorString = 'builtin:service.dbconnections.failure:filter(and(or(in("dt.entity.service",entitySelector("type(service),tag(~"dt.owner:~")"))))):splitBy("dt.entity.service"):sort(value(auto,descending))';
