In DQL, I would like to transform this value, which is in bytes, into gigabytes.
I’ve managed to do it but the result isn’t perfect. Is there a better way?
If you are doing this in a Notebook or Dashboard then you can use the ‘Units and formats’ function within the tile/section options to designate this field as being in Bytes and then tell Dynatrace to display as GB.
