From what I understand in documentation, it consume directly (instead of consume from the DDU…buffer that comes with Host-Unit)
But in multiple POC I’ve done, the CSM doesn’t consume them.
This comes as a bit of surprise for me (a good surprise though!!), but I can’t help but wondering is this expected? or something else is going on?
Best Regards,
Wai Keat
Hi Wai Keat,
Each Dynatrace environment gets 200,000 DDUs per year included for free. Extending Dynatrace (Davis data units) — Dynatrace Docs. In addition to that, whenever you have oneagent installed, based on the host units that are allocated to that host based on its size, Dynatrace provides you with additional set of metrics you can use for that specific host. https://www.dynatrace.com/support/help/monitoring-consumption/davis-data-units/metric-cost-calculation/#included-metrics-per-host-unit
I hope this helps.
Moe
Thanks Moe for the links shared.
That’s the thing, my observation is the 200k DDU isn’t consumed at all by CSM.
Whereas say for example, monitoring of F5 Load Balancer, we did see that the F5 metrics ingested consuming 200k free-tier DDU as expected.
That’s why I am confused CSM actually consumed the DDU directly? or consumed the DDU buffer comes with Host-Unit?
Documentation did explained the things well enough but my question is that in the real-world things doesn’t work as expected in documentation stated.
Hi Wai,
these metrics are still a billable item and customers need to take those into account when buying DDUs according to their needs (1 unit per data point, as described in docs).
Currently due to a technical issue these are not charged, but will soon. There will be some communication coming along with the changes as to avoid unwanted surprises.
Best regards,
Thomas
Thanks Thomas, clear explanation. Understood
