Calculating a Rolling Summary in a DQL
I have the following DQL, which returns a time series of a metric “incoming count in last minute” from a custom extension/generic db query.
timeseries query=sum(custom.db.query), :interval:1m,
filter:{in(dt.entity.custom_device,classicEntitySelector(“type(custom_device),entityName.equals(\“Incoming count in last 1 mins\”)”))},
by:{dt.entity.custom_device}
What I’m after is for every minute, return the incoming count for the last 60 minutes, i.e. calculating the total count for the last 60 minutes, every minute.
I could define a db query and another metric to calculate this, but currently we’re having performance/capacity issues so really don’t want to add another custom db query when I should be able to derive the answer.
P.S. bins or increasing the interval, doesn’t give me the granularity I need to compare against existing charts.
@pmurray30 - were you able to get a query for this, or a solution?
Hi @ChadTurner ,
At the time no, but after a year more of experience, it took me a couple of hours to come up with this.
timeseries {QueryRslt=Max(custom.db.query), timestamp=start()}, by: { dt.entity.custom_device } ,
  interval:1m,
  filter: { in(dt.entity.custom_device,
  classicEntitySelector("type(custom_device),entityName.equals(\"Incremental Count\")")) }
| fieldsAdd key = tolong(timestamp[]-arrayFirst(timestamp))/1000000000
| join on:{key} ,
  [timeseries {QueryRslt=Max(custom.db.query), timestamp=start()}, by: { dt.entity.custom_device },
    interval:1m, shift:-10m,
  | fieldsAdd key = tolong(timestamp[]-arrayFirst(timestamp))/1000000000]
| fieldsAdd delta=QueryRslt[]-right.QueryRslt[]
| fields timeframe, interval, delta
This works with a incremental count, but should be able to be adapted to a minute reading if you have more joins and add the readings.
Maybe there is a cleaner way of doing it, but at the time I ended up just adding another custom query.
