I have a Camel Quarkus application, and I can successfully view the Camel metrics at http://localhost:8080/metrics.
I’m using the Prometheus extension to expose the /metrics endpoint, and Micrometer to collect metrics.
My goal is to send these Camel Quarkus metrics to Dynatrace.
pom.xml
<!-- Core Micrometer extension -->
<dependency>
<groupId>io.quarkus</groupId>
<artifactId>quarkus-micrometer</artifactId>
</dependency>
<!-- Prometheus registry -->
<dependency>
<artifactId>quarkus-micrometer-registry-prometheus</artifactId>
</dependency>
<!-- Camel Micrometer for route metrics -->
<dependency>
<groupId>org.apache.camel.quarkus</groupId>
<artifactId>camel-quarkus-micrometer</artifactId>
</dependency>
<dependency>
<groupId>io.quarkiverse.micrometer.registry</groupId>
<artifactId>quarkus-micrometer-registry-otlp</artifactId>
<version>2.10.0</version>
</dependency>
The application is containerized using Docker. I have enabled Dynatrace monitoring on the container, and I’m able to see general metrics like Requests, Traces, CPU, and Memory in Dynatrace. To enable this, I have configured three environment variables for the container (in a .env file).
.env file
DT_TENANT=dwqtest
DT_TENANTTOKEN=PF7test
DT_CONNECTION_POINT=https://{environmentid}.live.dynatrace.com:443
Below is my application.properties configuration used to export Camel Micrometer metrics to Dynatrace (built in metrics).
Note : These same properties are also defined in the .env file and used when building the Docker container.
quarkus.micrometer.export.prometheus.enabled=true
quarkus.micrometer.export.prometheus.path=/metrics
quarkus.micrometer.binder.http-server.enabled=true
quarkus.camel.metrics.enable-instrumented-thread-pool-factory=true
quarkus.micrometer.enabled=true
quarkus.camel.metrics.enable=true
# OTLP exporter
quarkus.micrometer.export.otlp.enabled=true
quarkus.micrometer.export.otlp.url=https://{environmentid}.live.dynatrace.com/api/v2/otlp
quarkus.micrometer.export.otlp.headers=Authorization=Api-Token dttest.test
quarkus.micrometer.export.otlp.resource-attributes=service.name=my-camel-app
quarkus.micrometer.export.otlp.step=10s
Despite this, I do not see any of the Camel-specific metrics in Dynatrace in the Metrics or Data Explorer section.
Am I missing any required configuration ?
