At what granular levels can SAN performance metrics be monitored?
Yes, with proper integration:
- LUN level: If the SAN device exposes per-LUN metrics via SNMP or API, Dynatrace can collect and visualize them.
- Volume/Pool level: Most SAN APIs expose volume and pool stats like IOPS, bandwidth, utilization – all ingestible into Dynatrace.
- Port/Controller level: These are typically available via SNMP on the SAN device and supported via custom extension logic.
