can I assign the variable to a field and display as a field in dashboard
can I assign the variable to a field and display as a field in dashboard ?
I am trying this |fieldsAdd db_instance ==$DBName but this is not working. Please help. Thank you.
Have you tried to add a variable to a dashboard?
Best regards
Seems like you’re using double “=”, instead of a single equal sign. What you’re trying to do should work, example:
Yes, you should be able to using a single equals sign.
Thank you!
