Hi ,
We have created custom metrics and planning to use them in SRG using DQL. Is it possible to fetch custom metric data from Grail using DQL and do the SRG evaluation???
Heramb Sawant
Hi ,
Heramb Sawant
You will be able to fetch them using the timeseries instead fetch (DQL timeseries examples for Metrics — Dynatrace Docs)
Hi, did you find a solution for this? I’m facing the same issue — we’re trying to update a dashboard, but those custom metrics are not updating.
