Can you query by management zone in Data Explorer?
Any help appreciated.
Lou
Hello @crabbylou . Yes, you can filter for each MZ.
I meant in the query itself. Is that possible?
Only if MZ is a dimension.
but after a quick search I don’t see metrics with MZ as dimension.
Normally it’s preferred to use the Management Zones filter as already mentioned by @DanielS , but if you really want to filter it you can use the advanced mode and filter by entitySelector just as in the example below:
Just as reminder - the global Management Zone filter will always apply, so you can’t filter something that’s outside the global Management Zone filter.
Thanks so much to all! I got it to work in Data Explorer.
Very Helpful thanks..
