mkulov
July 7, 2020, 11:09pm
1
When I open Application page I can see Top 3 web request contributions as shown below for the same service:
Is there a way to make reporting of these web requests case insensitive so that both requests in the example above would group into a single entry?
Thank you,
Martin
Hello Marting,
Check your App configuration “case insensitive naming”
Hi @Rodrigo A.
This is a great and hidden feature, good to know it, but its look like its only for user actions on application side, @Martin K. is looking for the same feature on server side web request naming.
Meanwhile @Martin K. you can check if merged-services can do the job, or to use Service detection rules API
HTH
Yos
Hi Rodrigo,
Thanks for your reply.
As Yos points out this feature is about user action naming which is not the feature I am looking for.
@Yos , Thanks! I wil check if merged-services can do the job.
Martin
Maybe I’m confused but that screenshot is from Application/UserActions screen.
Also if you want to do a renaming globally on your server-side (Service level), you can use Create a new request naming rule — Dynatrace Docs
