Hi Folks,
Is it possible to rerun the cassandra or elasticsearch backup if it failed at night?
Thanks in advance.
Best regards,
Mizső
Hi Folks,
Thanks in advance.
Best regards,
Mizső
Hi @Mizső,
There was a similar question in the past, you can find it here:
Backup and restore Dynatrace Managed cluster with VMware snapshot
As far as I know, the solution provided there is still valid:
If a restored machine has same IP it might work. However this is not a supported solution. The only one that is supported is to follow restore procedure here:
as you see there are additional steps required that are not done when restoring from a snapshot
