Hello!
Does anyone know if it’s possible to change the background of the tile like in this dashboard below? I can’t tell if it’s markdown or code.
It is on the page Dynatrace observability platform
Hello!
Hello! To my knowledge, there is currently no way to configure background colors and the example shown on the website uses images injected via markdown, ie:
You can also inject base64 encoded images using markdown! (see example attached)
You have full control over the appearance of content in custom applications and have our component library at your disposal as well, just for your information:
Design token basics | Dynatrace Developer
If you’d like to suggest an enhancement to our dashboard design options, I would recommend creating a product idea here: https://community.dynatrace.com/t5/Ideas/ct-p/ProductIdeas
Be aware, you’ll need to be logged in as a Dynatrace user to access and contribute to this area of the community portal.
