Change timezone on new problem section
Hi Everyone,
I have noticed that in the classic problem section it shows a specific time (the time in my region) while in the new problem section it shows the time in UTC.
Will there be any settings to change the time zone in the new problem section?
Thanks in advance
Hi @soportetr ,
For me it is same, one thing you can try is updating the time zone on our profile and see if it fixes the problem.
Go to account management from bottom left of your Dynatrace screen and check here:
