changing flag values
Hi, everyone.
Last week I installed Oneagent in my server but I put this flag on true
‘set-infra-only=true’ because of the requirments of the bank, but
now they want to monitor all of the enviorment. so I need to put this flag
on ‘false’ to monitor everything. How can I change the flag? I checked
the config files but it says that you can’t change them through the config files.
Is there any way to change that flag through the Dynatrace UI?
Thank you so much for your time, regards!!
As long as its connected you can change that in the settings per host. Monitoring mode > flip the toggle for full stack mode.
Can also be done using oneagentctl tool: OneAgent configuration via command-line interface — Dynatrace Docs
Exactly, If you set the monitoring to 1/2 stack:
Navigate to the host and toggle full stack on. If you already have full stack on and want to do the reverse - go to 1/2 stack, then select “Edit” on the host then Monitoring Mode - and toggle off the fullstack mode:
Thank you a lot!!! It was ver useful
Both answers were very helpful, thank you!!
