Changing RUM rb beacon uri path
Hi Team,
do we know how we can change the rb beacon path from / to some folder like /temp so it can download the js to different path apart from root. by default it is using root and giving an error 404 , same error was there for ruxit agent which i have added in advanced custom parameter (eg /temp) which worked fine not sure about beacon.
Hi Daniel,
In Dynatrace current version Advanced Setup has not the option to setup where to send the data (POST path).
How we can control the POST path?
It should be using the same setting as the main javascript library.
I see that option in same place than screenshot.
Best regards
What version and SaaS/Managed are you using?
This setting is being moved from “Advanced setup” place to under “General settings” …
Only option under Advanced Setup/Capturing are:
While in General Settings the only option realated is Beacon Endpoint
Anyway in the docs Configure beacon endpoint for web applications in RUM Classic — Dynatrace Docs it seems that the location is now valid for providing the javascript and accepting the data.
