Hi! I have an issue with tooltips on the chart, once I click on the chart the tooltip becomes “sticky” and even though I am scrolling down the page I can still see the tooltip or even a few of them if I click on a couple of charts. Can you help me with clarifying this? It is worth mentioning that the behavior is the same for the default tooltip and the one that was added explicitly.
Hi @veranika_k
Thanks for reporting this. I haven been able to reproduce the issue. Even in other apps like notebooks it is the same behavior.
I have reached out internally about this issue. Will keep you posted.
Best,
Sini
Thank you!
Just got a response back from the team. The are aware of the issue and working on a solution. But unfortunately I can’t give you any ETA on the fix.
Cool! Will patiently wait for the solution. Thank you!
