Hello Team,
While troubleshooting RUM, I found the `x-dtHealthCheck SPECIAL_WEB_REQUEST` header. Could you please clarify the meaning of SPECIAL_WEB_REQUEST? Additionally, what other fields can be associated with this header? Is there any documentation available for reference?
Furthermore, I noticed the x-dtAgentId header. Could you explain what this ID refers to?
Any insights would be greatly appreciated.
Thank you in advance.
Akhil Jayendran
SPECIAL_WEB_REQUEST: This request is a special type, such as a beacon or a JavaScript agent request
The x-dtAgentId header contains the IDs of all agents with active Real User Monitoring (RUM) sensors involved in handling the request.
Hello @PacoPorro ,
Thank you so much for your reply,
Special type request means Java script ingested with agentless monitoring method? and where I can see a list of possible values under `x-dtHealthCheck` header ?
IDs of all agents means its a host ID of agent which is responsible for JavaScript ingestion?
Akhil Jayendran
