You can also use Dynatrace platform tokens[1] against classic endpoints such as Settings Objects[2].
Give your platform token the permission to access the specific account and environment and at least following scopes:
settings:objects:read
settings:objects:write
And call the API like this e.g.:
curl -X POST "https://{environmentid}.apps.dynatrace.com/platform/classic/environment-api/v2/settings/objects" \
-H "Authorization: Bearer dt0s16.L4ULG7YU.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" \
-H "Content-Type: application/json" \
-d '[
"schemaId": "builtin:alerting.maintenance-window",
"scope": "environment",
"value": {
"enabled": false,
"generalProperties": {
"name": "Scheduled maintenance window",
"description": "Created via API",
"maintenanceType": "PLANNED",
"suppression": "DETECT_PROBLEMS_DONT_ALERT",
"disableSyntheticMonitorExecution": false
"schedule": {
"scheduleType": "ONCE",
"onceRecurrence": {
"startTime": "2026-03-10T12:00:00",
"endTime": "2026-03-10T13:00:00",
"timeZone": "UTC"
[1]https://docs.dynatrace.com/docs/shortlink/platform-tokens[2]https://docs.dynatrace.com/docs/dynatrace-api/environment-api/settings/objects/post-object
