Classical Dashboards
Dear Dynatrace Gurus,
before you say move to the new dasboards with DQL, I would like t keep the old classical dashboards for now.
I have a couple of questions, I hope someone can help me?
1. I need to modify this classical dashboard query to display two important metrics (see below),
In this I use tech.generic.cpu.usage
builtin:tech.generic.cpu.usage:filter(eq(“dt.entity.process_group_instance”,PROCESS_GROUP_INSTANCE-2F6198CAE881F38A)):splitBy(“dt.entity.process_group_instance”):max
1. Process Group → Tecnology Specific Metrics → GC Time
2. Process Group → Tecnology Specific Metrics → GC Time
Where can I find the documentation for tech.generic.?.? (use to obtain more out of the box metrics)
2. I have a dashboard that uses the same query above, but if the process is down it says no data is available and you would see an empty no name chart. How can I show on the same dashboard to say process is down and not available and may be show as red - like Availability button.
Can someone help?
I appreciate your support.
Marwan…
Correction:
2. Process Group → Tecnology Specific Metrics → Response Time
The doc for the tech generic metrics is here: Built-in classic metrics — Dynatrace Docs
You can use the metric builtin:tech.generic.count to show if your process is Up (>1) or down (0). Try the single value visualization and mark 0 as red, >1 as green.
Thank you Dann, much appreciated it!
I used this for the CPU of that process like this
builtin:tech.generic.cpu.usage:filter(eq("dt.entity.process_group_ins
tance",PROCESS_GROUP_INSTANCE-98CB935943677AB7)):splitBy(“dt.entity.process_group_instance”):max
Then If I use the single count with the metric that you recomened
builtin:tech.generic.count:filter(eq(“dt.entity.process_group_instance”,PROCESS_GROUP_INSTANCE-98CB935943677AB7)):splitBy(“dt.entity.process_group_instance”)
I get this error
The dimension key `dt.entity.process_group_instance` has been referenced, but the metric has no such key.
If I remove the split
I get this error
I need to monior availability this particular process instance
Thanks for any feedback
How many Process Instances you do have for this process Process Group? This metric will look for Process Instances in your Process Group. The Process Group Instance is not a valid dimension for this metric. You should use the Process Group as filter/split by.
There are two instances one each host and the code above works like a charm. I filter by host and technology to find availability of each process in one dashboard. Do you another way to do this?
