Combined Outage Handeling
Dear All,
Is there a way to configure a combined outage handling for 2 different private locations?
e.g. there are two private locations configured to verify the login/logout functionality using the browser clickpath feature.
  • User # 1: It will be used only from one location.
  • User # 2: It will be used only from one location.
So, we want an alert in case an outage happens in both locations 2 times consecutively.
Note: We are looking at this without configuring it globally.
Babar
Is this monitor just running on 2 locations? In which case you could use either global or local outage handling options. If it occurs on more then just limit the local outage to 2/x locations
