Hi All,
Does anyone has the list of commands executed by dynatrace One Agent to collect the OS level and Network level metrics from the host ?
Thank You
Hi All,
Thank You
One Agent does not execute external commands in order to collect OS and Network level metrics. For OS level metrics, they are read directly from /proc (Linux) or from WinAPI calls (Windows). Network metrics are calculated from the traffic capture performed by Network Agent.
Hi Lukasz,
Thanks for your response! So it’s the same commands specified in the below link
When you say the Network metrics are calculated from the traffic capture, Can we understand that its sniffing every TCP packet that is passing through the server to get the information ?. Please help to clarify.
Regards
Sakthi
The linked page is for AppMon, which uses different code base. On a conceptual level we do it similarly, but there are differences.
