Compare Output Values Between Splunk and Dynatrace Using DQL
“I have the following Splunk query, and I’m trying to generate the corresponding output in Dynatrace.”
splunk query :-
index=ngss*_sourcefire_secevents | rex field=index “(?<Local_Market>\w.*?)_”
| eval BlockedStatus =
case(Like(src_ip,“64.39.106.%”) AND InlineResultID=4 ," Qualys Blocked",
Like(src_ip,“154.59.121.%”) AND InlineResultID=4," Qualys Blocked",
Like(src_ip,“64.39.106.%”) AND InlineResultID=0," Qualys Not Blocked",
Like(src_ip,“154.59.121.%”) AND InlineResultID=0," Qualys Not Blocked",
NOT Like(src_ip,“64.39.106.%”) AND InlineResultID=4,“Non Qualys Blocked”,
NOT Like(src_ip,“154.59.121.%”) AND InlineResultID=4,“Non Qualys Blocked”,
NOT Like(src_ip,“64.39.106.%”) AND InlineResultID=0,“Non Qualys Not Blocked”,
NOT Like(src_ip,“154.59.121.%”) AND InlineResultID=0,“Non Qualys Not Blocked”)
| stats count by Local_Market BlockedStatus | rename eventtype as “Local Market”,count as “Total Critical Events”
corresponding DQL is as below , where i am getting Null value ..
Please not that in DQL Src_ip is consider as “InitiatorIP”.
DQL query is as below :-
fetch logs // scanLimitGBytes: , samplingRatio: 1000
| filter contains(dt.security_context,“ngss”)
| parse content,“”“LD 'InlineResultID”:’ string:InlineResultID “,” “”"
//| parse content, “”“LD ‘InitiatorIP’[^,]{1,100}?:“InitiatorIP’,'””“”
| fieldsAdd market = substring(dt.security_context, to: indexOf(dt.security_context, “_”))
| parse content, “”" LD ‘InitiatorIP\“:\”’ IPADDR:InitiatorIP “”"
| parse content, “”" LD ‘InitiatorIP=’ IPADDR:InitiatorIP “”"
| fieldsadd QualysBlocked=if((like(SrcIP"154.59.121%“) or like(SrcIP"64.39.106.%”) AND contains(InlineResultID,“0”) or contains(InlineResultID,“4”)),QualysBlocked)
| fieldsadd QualysNotBlocked=if((like(SrcIP"64.39.106%“) OR like(SrcIP"154.59.121.%”) AND contains(InlineResultID,“0”) or contains(InlineResultID,“4”)),QualysNotBlocked)
| fieldsadd NonQualysBlocked=if((like(SrcIP"64.39.106%“) or like(SrcIP"154.59.121%”) AND contains(InlineResultID,“0”) or contains(InlineResultID,“4”)),NonQualysBlocked)
| fieldsadd NonQualysNotBlocked=if((like(SrcIP"64.39.106%“) or like(SrcIP"154.59.121.%”) AND contains(InlineResultID,“0”) or contains(InlineResultID,“4”)),NonQualysNotBlocked)
| fieldsADD BlockedStatus = coalesce(QualysBlocked,QualysnotBlocked,NonQualysBlocked,NonQualysNotBlocked)
//| fieldsADD Blockedstatus = coalesce(QualysBlocked,QualysnonBlocked)
| summarize count() ,by:{market,BlockedStatus}
Hey @sharmas2 ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
