Complex WQL queries in Extension 2.0
(Get-WmiObject -Query “select * from MSCluster_Resource where type=‘IP Address’” -namespace “root\mscluster”).privateproperties
In Powershell I can quite easily do the following:
(Get-WmiObject -Query "select * from MSCluster_Resource where type='IP Address'" -namespace "root\mscluster").privateproperties
This will provide me with the expanded information from the privateproperties of the MSCluster_Resource type.
Is it possible to the same using WQL in Extension 2.0?
I dont think so as Dynatrace uses their own language - DQL
DQL is something else than what is being used in the extension framework. WMI declarative extensions uses WQL.
You cannot access additional attributes on the returned query, you’d have to make it all part of the query. Is there a reason that you cannot in this case?
Hi Mike!
As far as I have been able to figure out, there is no way of writing this as a WQL. And believe me I have tried.
If you have knowledge otherwise please do let me know.
I didn’t try but if it won’t be returned like this I think you’re stuck with Python in EF1, reaching out to our services team for Python in EF2, or setting up a task that feeds the result in through the OneAgent endpoints.
wmiNamespace: root\mscluster
query: SELECT PrivateProperties FROM MSCluster_Resource WHERE type='IP Address'
Ok,
So basically we are stuck with waiting on DT to release python for ext2 in the wild?
We have basically 99% of the functionality, but not the remaining 1%
