@sivart_89 I have to say, this extension is AMAZING. We try to stay as close to native functionality as we can but in this case, the extension provides so many more benefits over native.
1) Cost, we have nearly 2,000 cert checks (yes, we have that many purchased certs). This extension lets us manage them in DT but run far more robust cert checks at no charge (unless you turn on the extensions optional metric recorder, which we do).
2) We check certs every 24 hours. DT’s solution only allows a max of 60 minutes between checks, which again, you’d have to now pay for because you’re using DTs native solution.
3) Problems won’t flutter…this extension not only opens a far more informative problem but it then self-checks every minute on the problems it opened to see if the cert issue has been resolved or not. If not, it keeps the same problem open for days, like it should. DT allows only for a max of 2 hours for a problem to exist before it closes it automatically (or marks as frequent issue [i think this is design flaw they hid behind frequent issue]).
4) This one updates how many days until the cert expires, Dynatrace just tells you it will expire in whatever the threshold value is (30 days or whatever)
5) The Event details and the Problem details tell you far more information like # of days from current date, CommonName, Issuer, NotAfter, NotBefore. It goes negative in days if the cert expired XXX days ago.
We actually have a few “SSLxx” profiles pre-setup. the XX is how many days till expiration to alert. This lines up with the TAG on the Synthetic. So if someone says instead of 30 days i want to be alerts in 15 days we just change the tag from SSL30 to SSL15. And now it auto adjusts to the new threshold.
WishList: I wish there were a way to do a Warning and a Critical alert. I have multiple ideas on ways to do this but the most user friendly would be a checkbox to activate “Warning Level” then allow the user to set another value for when to trigger a Warning alert if it goes below said value. It’s up to the user to not be stupid and enter 15 for warning and 30 for critical.
Wishlist#2: ability to handle wildcard certificates. No idea how to suggest this but know it’s something we need.
