Increase Synthetic Monitor frequency to 1 day or week
For Synthetic Monitors setup for checking SSL Certificate Validity can we have frequency of a day or week as continous monitoring is not needed.
You could use my colleagues Advacned SSL Check Certificate Plugin which allows for checks once a day.
Or you could set the test to On Demand only and trigger it once a day or week as needed via a script.
You need an ActiveGate but if you don’t have because you are doing the http synthetic monitoring from the public location that Dynatrace allow you can’t use the Plugin.
It will be easy to change the frequency on the web interface
