How to run synthetic monitor only once per day (SSL certificate check)
Hi All,
We want to validate SSL certificate expiry date so we can use “HTTP monitor” , this monitor can be run from 1min to 60mins frequency but we want this to run only once per day.
Please suggest how it can be done.
Guru Gogi
Hן @Gogi
IMO You can set Maintenance Window with Disable synthetic monitor execution for that
HTH
Yos
Hello @Gogi ,
For your use case, you need to run the synthetic monitor on-demand through the Dynatrace API. Synthetic monitor executions API v2 - POST batch execution — Dynatrace Docs
This can be done through any tool with scheduling and especially in Dynatrace Saas through Workflows.
Note that for this use case there’s probably a better option with the SSL Certificate Monitor extension.
