We’re bombarded with alerts for AWS auto scaling EC2 hosts.
The alerts are P2 due to severity, can we make and suppress this autoscale host alerts from Dynatrace anyway unimpacting the genuine ones, please?
Please assist.
Munawar
@munawarhossain2 Take a look to see if these metrics are enabled for alerting , you can disable the once that you do not need
How do I turn off the metric? The agent is there on the cluster and EC2 instances are auto scaling which are throughing host unavailability errors.
This is not related to extension monitoring but for full stack.
Can you share which problem was created in Dynatrace console?
Best regards
Yeah, you can switch off that if you do not want to get alerts.
Best regards
But, I’m afraid too if this will suppress any genuine cases too?
