Hello All,
i am trying to use Tomcat JMX extension to monitor connection pools.
I have added the host name in which Kubernetes pods are running . After configuring the status is still PENDING , and no logs to check what is the issue .
Hello All,
Can you check OneAgent extensions logs?
Best regards
No signs of Tomcat JMX in extension logs
Are you checking extension OneAgent logs directory? If you deploy extension, logs are there.
Best regards
